Nitrogen plasma simulation: cross section file?
I followed the webinar about plasma simulation, and they told something about
a french institut in Toulouse who was supposed to provide the cross sections
data for different gases.like the argon.txt.. but for nitrogen..
Anyone that took more attention than me?
Can somebody help on that? any file that would help getting away from Argon?
Thank you
Lukas
Germany
7 Replies Last Post 18.04.2017, 04:11 GMT-4
Posted: 1 decade ago 29.12.2010, 08:24 GMT-5
for example, search at internet for:
cross-section for impact electron with N2+
next use form profiles of " cross-section electron impact with N2+"
parviz
[QUOTE] Hello, for example, search at internet for: cross-section for impact electron with N2+ next use form profiles of " cross-section electron impact with N2+" parviz
Daniel Smith COMSOL Employee
Posted: 1 decade ago 29.12.2010, 10:08 GMT-5
Hi, cross section data can be found here:
www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php
The file needs to be modified slightly before it can be imported into COMSOL. The user's guide explains the required format.
/ Dan
Hi, cross section data can be found here: http://www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php The file needs to be modified slightly before it can be imported into COMSOL. The user's guide explains the required format. / Dan
Posted: 1 decade ago 17.01.2011, 06:32 GMT-5
Hi Daniel,
What was the source used for the ionization cross sections for the Argon metastable used in the model library ie. e+Ars=>2e+Ar+ - I cannot find this information on the University of Toulouse electron scattering database - www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php.
Kind Regards,
Sean
Hi Daniel, What was the source used for the ionization cross sections for the Argon metastable used in the model library ie. e+Ars=>2e+Ar+ - I cannot find this information on the University of Toulouse electron scattering database - http://www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php. Kind Regards, Sean
Posted: 1 decade ago 15.11.2013, 09:38 GMT-5
Hello Daniel,
I am simulating nitrogen dc plasma for DBD reactor in dc discharge interface. I used database from Phelps for nitrogen cross section. For importing nitrogen database to COMSOL, it needs "statistical weight ratio" of final state to initial state (as 2nd number of 3rd line). I tried to search, but could not find this number for nitrogen excitation reactions.
Could you please help me, by sharing the source/reference to these values or procedure how to calculate them?
I would like to thank you in advance. Looking forward to hear from you.
Best Regards,
Bhaskar
Hello Daniel, I am simulating nitrogen dc plasma for DBD reactor in dc discharge interface. I used database from Phelps for nitrogen cross section. For importing nitrogen database to COMSOL, it needs "statistical weight ratio" of final state to initial state (as 2nd number of 3rd line). I tried to search, but could not find this number for nitrogen excitation reactions. Could you please help me, by sharing the source/reference to these values or procedure how to calculate them? I would like to thank you in advance. Looking forward to hear from you. Best Regards, Bhaskar
Posted: 1 decade ago 09.09.2014, 02:29 GMT-4
I meet the same problem with you, how do you deal with this question finally?
Posted: 1 decade ago 14.03.2015, 10:59 GMT-4
Have you found the solution?
Best regards.
Hello, Have you found the solution? Best regards.
Posted: 9 years ago 18.04.2017, 04:11 GMT-4
I HAVE THE SAME PROBLEM. HAS anyone solved?
