                                24.12.2010, 04:28 GMT-5
if you are in RF or ACDC you must check that you have enough mesh elements inside a wavelength to resolve correctly the field, and as the wavelength changes with the index of refraction, or the dielectric constant, one way is to impos that the maximum mesh size is related to these variables.
In the example then main reason is to have a coarse mesh to be able to solve it on a laptop, but to ensure that is adapted everywhere, hence the dependency on "1/n" wich is proportional to 1/sqrt(dielectric_constant). You could as well use 0.01/sqrt(dielectric constant) if you have enough RAM, but overdoing it just requires more time without a significant increase in correctness of the result
                                27.12.2010, 14:13 GMT-5
Thanks a lot for your reply. I have another question concerning the equation of the waveguide port. As shown in the example of the microwave oven,  there is a rectangular waveguide operating in TE10 mode having power of 1KW. I have two concerns: regarding the power, it is diminished to half its value in port tab to be 500W instead. Second, I can't understand the equation of the Eo having the value cos(pi*(y-13.5[cm])/7.8[cm]) in the Z direction. What does 13.5 come from? and if I changed the location of the waveguide, what parameters would change in the equation?
Awaiting your kindly reply,
Iman Hassaballa
Iman Hassaballa
                                14.09.2011, 11:48 GMT-4
                                                    The example in model library was meant for running the model on low end laptops. If you have good computer you can use whole Microwave oven and put full rectangular wave guide piece and simply assign TE10 mode on rectangular section cross section. In this case you do not need to E field expression. However, this approach is just good for understanding the interaction of microwave with the materials. For actual simulation, one has to take into account of actual wave-guide port as we see in the domestic microwave oven and use magnetron as coaxial source.
With best,
Sohan Birla,
With best,
Sohan Birla,
