What is the diffrence btw PML and 'scattering boundary condition'?
Setting a subdomain as PML and a boundary condition as scattering boundary can be used alternatively?
I checked it for one tutorial expamle( dielectric scattering PML ) and almost identical result is produced.
2 Replies Last Post 12.01.2011, 18:01 GMT-5
Posted: 1 decade ago 26.12.2010, 14:41 GMT-5
if you read the doc on RF for v4.1 you will get a rather ind epth explanation I believe:
in very short:
A BOUNDARY "port" or a "scattering" condition are to define absorbing/source electric boundaries, in a distributed or a lumped (port) , but in well defined way, this means among other that the wave can travel in both direction from or through the boundary.
While the PML is a DOMAIN feature simulating an infinite domain where ANY wave can propagate and dissapear (without being reflected back)
Hi if you read the doc on RF for v4.1 you will get a rather ind epth explanation I believe: in very short: A BOUNDARY "port" or a "scattering" condition are to define absorbing/source electric boundaries, in a distributed or a lumped (port) , but in well defined way, this means among other that the wave can travel in both direction from or through the boundary. While the PML is a DOMAIN feature simulating an infinite domain where ANY wave can propagate and dissapear (without being reflected back) -- Good luck Ivar
Posted: 1 decade ago 12.01.2011, 18:01 GMT-5
Sir
If I want to caculate the Q factor of the whispering gallery mode in the 2D optical circular disk microdisk, what kind of boundary condtion shall I use? The Q factor is just limited to the radiation if I dont consider the absorption of the material .
Another question is shall I use the eigenfrequency analysis to calculate the eigenvalue? After that ,I chose the eigenvalues with small real parts(which with high Q) and calculate the Q factor in the which the imaginary part is divided by the real part. Is the method correct?
Thank you
in very short:
Sir If I want to caculate the Q factor of the whispering gallery mode in the 2D optical circular disk microdisk, what kind of boundary condtion shall I use? The Q factor is just limited to the radiation if I dont consider the absorption of the material . Another question is shall I use the eigenfrequency analysis to calculate the eigenvalue? After that ,I chose the eigenvalues with small real parts(which with high Q) and calculate the Q factor in the which the imaginary part is divided by the real part. Is the method correct? Thank you [QUOTE] Hi if you read the doc on RF for v4.1 you will get a rather ind epth explanation I believe: in very short: A BOUNDARY "port" or a "scattering" condition are to define absorbing/source electric boundaries, in a distributed or a lumped (port) , but in well defined way, this means among other that the wave can travel in both direction from or through the boundary. While the PML is a DOMAIN feature simulating an infinite domain where ANY wave can propagate and dissapear (without being reflected back) -- Good luck Ivar [/QUOTE]
