Boolean Operation Difference using Selection
Posted 12.10.2016, 13:36 GMT-4 0 Replies
Also when I create a simple cell array containing all the strings of geometries that are needed in matlab the comsol syntax does not use a cell array, which is the type where strings are stored in matlab (are not stored in lists). Simply looping does not work either for the input because then only the last (cyl%n) is used as input for the difference.
model.geom('geom1').feature('dif1').selection('sel1').set({'sel1'}); #does not work
model.geom('geom1').feature('dif1').selection('sel1').set({a}); with a = {'cyl1' 'cyl2' 'cyl3'}; #does not work
for i = 1:length(n);
str = sprintf('cyl%d', i);
model.geom('geom1').feature('dif1').selection('sel1').set({str});
end
#only gives a difference with the last cylinder.
I hope someone can help me with this!
Thank you in advance
Hello Maria Hagelaars
