particle beam generation
Hello.
Im new to comsol so please forgive me for newbie questions.
I have a fairly simple problem of heat deposition of electron beam on a lithium plate. Modeling the plate is no big deal, but I dont know how to generate a well defined particle beam. What kind of model do i use? Is there any tutorial or similar problem already modeled? Thank you in advance.
4 Replies Last Post 04.10.2011, 12:04 GMT-4
Posted: 1 decade ago 15.01.2011, 05:14 GMT-5
Hello again.
I see that after a weak and 88 views I still got no answer.
Is it even possible to simulate a particle beam with energy deposition into the thin plate?
All I need is a module which uses Bethe-Bloch formula.
Hello again. I see that after a weak and 88 views I still got no answer. Is it even possible to simulate a particle beam with energy deposition into the thin plate? All I need is a module which uses Bethe-Bloch formula.
Posted: 1 decade ago 15.01.2011, 09:19 GMT-5
Did you look at the tutorials or documentations for the version you use? There are several materials such as modeling guide, releases, model library for AC module and so on. I suggest model library doc. especially since it has models implemented for several areas.
Posted: 1 decade ago 25.01.2011, 14:38 GMT-5
Yes, I have gone through tutorials and manuals once more.But i still havent found a way to incorporate energy deposition of a beam of particles into the target. Any more practical advices on which module i should use or how to parse this problem? Is this even possible in Comsol?
Thanx
Yes, I have gone through tutorials and manuals once more.But i still havent found a way to incorporate energy deposition of a beam of particles into the target. Any more practical advices on which module i should use or how to parse this problem? Is this even possible in Comsol? Thanx
Posted: 1 decade ago 04.10.2011, 12:04 GMT-4
Thanx
Have you had any luck with this or responses elsewhere? What I've done up until now is plot the Lorentz Force using just the F=-q(v x B) portion since I am looking at only static magnetics, but I would be curious to see what you've learned.
~Brock
[QUOTE] Yes, I have gone through tutorials and manuals once more.But i still havent found a way to incorporate energy deposition of a beam of particles into the target. Any more practical advices on which module i should use or how to parse this problem? Is this even possible in Comsol? Thanx [/QUOTE] Have you had any luck with this or responses elsewhere? What I've done up until now is plot the Lorentz Force using just the F=-q(v x B) portion since I am looking at only static magnetics, but I would be curious to see what you've learned. ~Brock
