2-D plate model
I am trying to build simple model to analyse the eigenfrequencies of a freely vibrating irregularly-shaped 2-D plate. I have selected the plate model in the structural mechanics module. The shape I have imported from a .dxf CAD file. I have around 8000 elements, an amount which I believe to suffice.
When I try to solve my model all I get is an error of undefined value in the stiffness matrix. For a 3-D square plate with the same settings, everything seems to be working fine.
Can someone help me detect what have I forgotten in this model, because it does not work?
Yours,
Henna from snowy Finland
6 Replies Last Post 26.11.2011, 12:21 MEZ
Posted: 1 decade ago 12.01.2011, 16:01 MEZ
I have some problems too to run your file too, try to redefine a fresh model.
You must know by now that v4.0 is sensitive to model changes and modifications, you should get hands on the latest 4.1 its much smoother :)
If I extract your geometry and remake a plate model it works OK for me
Hi I have some problems too to run your file too, try to redefine a fresh model. You must know by now that v4.0 is sensitive to model changes and modifications, you should get hands on the latest 4.1 its much smoother :) If I extract your geometry and remake a plate model it works OK for me -- Good luck Ivar
Posted: 1 decade ago 12.01.2011, 16:28 MEZ
and thanks for a swift reply. I did not think of redefining the model before. I exported the geometry, and made a new model. Yet, I get the very same problem persisting; an undefined value found (in the stiffness matrix). I have also tried simply restarting COMSOL..Debugging one's models is very difficult in COMSOL.
It might be that I am missing something very simple in my model. There is nothing in particular that I should do to the imported geometry, before meshing? Is it possible for you to post the plate model online, so that I can make a comparison?
However, since you managed to run the model, I think the problem could also be my computer, or my version of the software.
Thanks again.
Henna
Hi, and thanks for a swift reply. I did not think of redefining the model before. I exported the geometry, and made a new model. Yet, I get the very same problem persisting; an undefined value found (in the stiffness matrix). I have also tried simply restarting COMSOL..Debugging one's models is very difficult in COMSOL. It might be that I am missing something very simple in my model. There is nothing in particular that I should do to the imported geometry, before meshing? Is it possible for you to post the plate model online, so that I can make a comparison? However, since you managed to run the model, I think the problem could also be my computer, or my version of the software. Thanks again. Henna
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 12.01.2011, 16:57 MEZ
The problem is that the model uses a Poisson's ratio that is exactly 0.5, which leads to a division by zero in the computation (and hence an error for Inf in the matrix rows) for a linear elastic material model. That material model uses a factor (1-2*nu), where nu is Poisson's ratio, in the denominator for the elasticity matrix, so a value of 0.5 is not allowed.
Try using a Poisson's ratio that is smaller than 0.5. Then the computation should run just fine.
Magnus Ringh, COMSOL
Hi, The problem is that the model uses a Poisson's ratio that is exactly 0.5, which leads to a division by zero in the computation (and hence an error for Inf in the matrix rows) for a linear elastic material model. That material model uses a factor (1-2*nu), where nu is Poisson's ratio, in the denominator for the elasticity matrix, so a value of 0.5 is not allowed. Try using a Poisson's ratio that is smaller than 0.5. Then the computation should run just fine. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 13.01.2011, 07:45 MEZ
I missed that one ;), as I redefined the material
Hi I missed that one ;), as I redefined the material -- Good luck Ivar
Posted: 1 decade ago 13.01.2011, 12:47 MEZ
Oh, yes, indeed. That is the little thing that I missed. I had just selected some of the material properties wrong after reducing the material from orthotropic to isotropic , and the model dimensions from 3D to 2D. One should be careful to remember the actual physics behind!
Thank you very much!
Oh, yes, indeed. That is the little thing that I missed. I had just selected some of the material properties wrong after reducing the material from orthotropic to isotropic , and the model dimensions from 3D to 2D. One should be careful to remember the actual physics behind! Thank you very much!
Muhammad Mohsin Rehman
Posted: 1 decade ago 26.11.2011, 12:21 MEZ
I am also facing the same difficulty for microwaves heating model. Initially, I was simulating a layer of oil lying over a layer of oil and was getting some results, although not convinced.
Then I defined another layer of oil below the layer of water and tried to simulate it but it gave me the following error:
Undefined value found.
- Detail: Undefined value found in the stiffness matrix.
There are 1160 equations giving NaN/Inf in the matrix rows for the variable mod1.E10
at coordinates: (0.0016633,0.00180792), (0.00332659,0.00361583), (0.00382242,0), (0.00714901,0.00361583), (0.00764484,0), ...
There are 290 equations giving NaN/Inf in the matrix rows for the variable mod1.E20
at coordinates: (0.00548572,0.00180792), (0.0016633,0.00514125), (0.00469918,0.00847458), (0.0085216,0.00514125), (0.0191354,0.00333333), ...
There are 290 equations giving NaN/Inf in the matrix rows for the variable mod1.E21
There are 871 equations giving NaN/Inf in the matrix rows for the variable mod1.Ez
at coordinates: (0,0), (0.0114673,0), (0.00573363,0), (0.00249494,0.00271187), (0.00498989,0.00542375), ...
and similarly for the degrees of freedom, NaN/Inf in the matrix columns
I have not even changed any other material, BC or property of the model and there is no red flag in the material section either but still I am facing this error, why???
Can you please help!
Hi, I am also facing the same difficulty for microwaves heating model. Initially, I was simulating a layer of oil lying over a layer of oil and was getting some results, although not convinced. Then I defined another layer of oil below the layer of water and tried to simulate it but it gave me the following error: Undefined value found. - Detail: Undefined value found in the stiffness matrix. There are 1160 equations giving NaN/Inf in the matrix rows for the variable mod1.E10 at coordinates: (0.0016633,0.00180792), (0.00332659,0.00361583), (0.00382242,0), (0.00714901,0.00361583), (0.00764484,0), ... There are 290 equations giving NaN/Inf in the matrix rows for the variable mod1.E20 at coordinates: (0.00548572,0.00180792), (0.0016633,0.00514125), (0.00469918,0.00847458), (0.0085216,0.00514125), (0.0191354,0.00333333), ... There are 290 equations giving NaN/Inf in the matrix rows for the variable mod1.E21 at coordinates: (0.00548572,0.00180792), (0.0016633,0.00514125), (0.00469918,0.00847458), (0.0085216,0.00514125), (0.0191354,0.00333333), ... There are 871 equations giving NaN/Inf in the matrix rows for the variable mod1.Ez at coordinates: (0,0), (0.0114673,0), (0.00573363,0), (0.00249494,0.00271187), (0.00498989,0.00542375), ... and similarly for the degrees of freedom, NaN/Inf in the matrix columns I have not even changed any other material, BC or property of the model and there is no red flag in the material section either but still I am facing this error, why??? Can you please help!
