9 years ago
22.11.2016, 17:07 MEZ
You might have selected both domain as solid in heat transfer module.
9 years ago
23.11.2016, 09:23 MEZ
@Sohan, thank you for the reply.
I have the following selected
where 1 is the outside solid and 2 is the inside fluid
Heat transfer in Fluids 3 (ht3) : [1 & 2]
Heat transfer in Fluids 1 : [1 & 2 (both overridden)]
Heat transfer with Phase Change 1 : [2]
Heat Transfer in Solids 1 : [1]
in the Laminar Flow domain only domain 2 is selected
9 years ago
29.11.2016, 09:03 MEZ
I still have not been able to figure this out...
the domains which are currently selected seem to make sense, is there a mistake there?
where else could I look to see why I am unable to select the fluid in the Non isothermal flow component?
9 years ago
30.11.2016, 10:06 MEZ
so it seems the only way I can select the fluid domain in the 'non isothermal flow' component is to disable 'Heat transfer with Phase change' in 'heat transfer in fluids'
Are these two modules not able to work together? If so, how do I manually couple the heat and fluid flow?
many thanks
Jesse
many thanks
Jesse
9 years ago
30.11.2016, 16:18 MEZ
You do not need separate solid and liquid node in heat transfer module when you use phase change material node. Depending on initial temperature value of the domain, it will behave like solid or liquid. In laminar flow physics node include both domains. See the attached model I created based on your problem description. Hope it will help you.
With best wishes,
Sohan
With best wishes,
Sohan
9 years ago
01.12.2016, 16:55 MEZ
Thank you very much Sohan for your help.
I have tried with 5.1 and on another PC which has 5.2 but I am unable to open the example you provided. I guess it was created with 5.2a? Is there any way I could convert this to either 5.1 or 5.2?
many thanks
Jesse
many thanks
Jesse
9 years ago
06.12.2016, 10:17 MEZ
@Sohan,
thank you again for your help. I was not able to find a way to convert your example to v5.1.
Do you think you could write a short description of how you used the laminar flow module? How did you incorporate the phase change?
many thanks
Jesse
@Sohan,
many thanks
Jesse
Jonas Inhestern
COMSOL Employee
9 years ago
06.12.2016, 16:22 MEZ
Dear Jesse,
the ability to combine Nonisothermal Flow multiphysics node with Phase Change Material feature has been introduced in COMSOL version 5.2a. We recommend to update to this version to benefit from this new capability. For further information please contact the COMSOL support team:
www.comsol.de/support
Jonas Inhestern
Dear Jesse,
https://www.comsol.de/support
Jonas Inhestern
