creating plot in comsol 3.5?
I can't figure out how to create a plot in comsol. I have comsol 3.5, could someone explain what i have to click step-by-step in generator 2D from model library>AC/DC Module> Motors and Drivers to see plot which is showed on Figure 3-4 in documentation?
1 Reply Last Post 19.01.2011, 12:33 MEZ
Posted: 1 decade ago 19.01.2011, 12:33 MEZ
Hi Patryk,
I don't have the AC/DC module installed, so I can't exactly explain how to get your specific figure.
But in general in v3.5 to get plots, you would click on "postprocessing" in the menu bar and then on "plot parameters".
You can then choose between many plot types, such as surface plots, contours, arrows, streamlines, etc.
You can also choose, which parameter you'd like to plot or define your own expressions.
Did this help?
Juergen
Hi Patryk, I don't have the AC/DC module installed, so I can't exactly explain how to get your specific figure. But in general in v3.5 to get plots, you would click on "postprocessing" in the menu bar and then on "plot parameters". You can then choose between many plot types, such as surface plots, contours, arrows, streamlines, etc. You can also choose, which parameter you'd like to plot or define your own expressions. Did this help? Best regards, Juergen
