Resonance frequency of a piezoelectric cube
I am trying to find the resonance frequency of a piezoelectric cube, using the Piezoelectric Devices physics of COMSOL 4.0.
The edge of the cube is 500e-9m long, and its material is Zync Oxide.
I mean to do so by two studies:
1- Frequency Domain study.
I put a voltage of 40mV on a face of the cube, the opposed face being the ground. This potential induces a deformation in the cube.
I do the study from 1e9 to 10e9 Hz with a 10e6Hz step.
I don't really know how to see the resonance... So I guess the best solution must be to plot the displacement of a corner depending on the frequency ( disp=f(freq) )?
I see something looking like a resonance frequency around 3.4GHz, but I see several other maximums at higher frequencies (8.1GHz, 8.3GHz....) , that I can't explain.
Could you tell me if it can be because of some wrong or missing parameters? or else they would be normal..
2- Eigenfrequency
I try to find eigenfrequencies around the 3.4GHz seen before (6 values by def.) , but the software seems to give me random values around this 3.4GHz frequency.
Even stranger, I will get eigenfrequencies for any eigen value I put (like 5 or 6 GHz).
Finally, sometimes I get unexplainable Complex eigenfrequencies... Do you know why?
Thanks for your time,
Regards
Michel
6 Replies Last Post 12.09.2012, 05:25 MESZ
Hello Jean-Michel Poirier
Posted: 1 decade ago 16.03.2011, 14:40 MEZ
The best way is to plot the impedance of the piezo cube and check the resonances
User COMSOL
The best way is to plot the impedance of the piezo cube and check the resonances -- User COMSOL
Posted: 1 decade ago 27.03.2012, 23:46 MESZ
can you explain me how i can plot impedance?my project consist a zinc that some Al electrodes are on that,i apply 10v to one of electrodes and i want to get resonsnce frequency and admittance value(matrix) but i cant.
Hi, can you explain me how i can plot impedance?my project consist a zinc that some Al electrodes are on that,i apply 10v to one of electrodes and i want to get resonsnce frequency and admittance value(matrix) but i cant.
Posted: 1 decade ago 21.08.2012, 11:26 MESZ
Hi there,
I did a similar analysis using version 4.2a. Instead of applying an electrical potential, apply a terminal constraint of voltage type. Then after the frequecy domain analysis if you plot -- abs(1/imag(pzd.Y11)); you will get the required impedance trace. Looking at the impedance trace, you can find the resonance and anti-resonance frequencies of the model.
Hope it helps.
Anurag Dhutti
Hi there, I did a similar analysis using version 4.2a. Instead of applying an electrical potential, apply a terminal constraint of voltage type. Then after the frequecy domain analysis if you plot -- abs(1/imag(pzd.Y11)); you will get the required impedance trace. Looking at the impedance trace, you can find the resonance and anti-resonance frequencies of the model. Hope it helps. Anurag Dhutti
Posted: 1 decade ago 08.09.2012, 16:02 MESZ
Hello Anurag:
I began to study comsol lately, could you tell me how to plot the connection of impedance and frequency. when I try your suggestion why the software tell me: failed to value the expresion imag(pzd.Y11) and abs(1/imag(pzd.Y11)). look forward to your reply.
thank you,
yang
Hello Anurag: I began to study comsol lately, could you tell me how to plot the connection of impedance and frequency. when I try your suggestion why the software tell me: failed to value the expresion imag(pzd.Y11) and abs(1/imag(pzd.Y11)). look forward to your reply. thank you, yang
Posted: 1 decade ago 11.09.2012, 11:42 MESZ
Hi Yang,
The only reason I can think of is that you might have assigned an electrical constraint of 'Electric Potential' instead of 'Terminal'. Assign Terminal constraint type on the desired surface of your geometry and then in the properties window, you can choose the terminal to be a 'Voltage Type' of the desired voltage.
This worked for me so hope it does for you, but if it doesn't, I'll be happy to look at your model to get a better understanding of the problem.
Best Regards,
Anurag Dhutti
Hi Yang, The only reason I can think of is that you might have assigned an electrical constraint of 'Electric Potential' instead of 'Terminal'. Assign Terminal constraint type on the desired surface of your geometry and then in the properties window, you can choose the terminal to be a 'Voltage Type' of the desired voltage. This worked for me so hope it does for you, but if it doesn't, I'll be happy to look at your model to get a better understanding of the problem. Best Regards, Anurag Dhutti
Posted: 1 decade ago 12.09.2012, 05:25 MESZ
Hi Anurag,
Thanks for your reply. Yes you were right, I use the wrong electrical constraint. Now I have done the impedance analysis. But I want to know that whether "abs(1/imag(pzd.Y11))" is the image part of the impedance?
If I want to konw the real part of impedance, am I right to use the function "abs(1/real(pzd.Y11))"? But in my model, the curve "abs(1/real(pzd.Y11)) vs frequency" is nothing. it is so strange, I don't know why, could you help me?
Besides, my model is a very simple one(just for try): a pzt film, one surface is ground, the other surface is terminal with voltage. frequency domain 150000:1000:750000.
Yang
Hi Anurag, Thanks for your reply. Yes you were right, I use the wrong electrical constraint. Now I have done the impedance analysis. But I want to know that whether "abs(1/imag(pzd.Y11))" is the image part of the impedance? If I want to konw the real part of impedance, am I right to use the function "abs(1/real(pzd.Y11))"? But in my model, the curve "abs(1/real(pzd.Y11)) vs frequency" is nothing. it is so strange, I don't know why, could you help me? Besides, my model is a very simple one(just for try): a pzt film, one surface is ground, the other surface is terminal with voltage. frequency domain 150000:1000:750000. Thanks for your time Yang
