Modulo function for making pulse train.
Trying to make a pulse train by combining the heaviside function with the modulo function, as described in a previous post.
The heaviside works fine for one pulse:
(flc2hs(5- t),1)
But when I substitue t for the modulo function:
flc2hs(5- (mod(t,0.01)),1)
the function gives a constant output of 1.
Could someone explain to me what the modulo function actually does as it is not explained in the help files
Thanks for the help.
3 Replies Last Post 05.04.2013, 19:56 MESZ
Posted: 1 decade ago 28.01.2011, 07:24 MEZ
first of all, as you state there are several threads already about how to generate a pulse train, in v4 it has been made very easy with the "periodic" check box too and predefined pulse functions.
One thing with your function, I do not see how you pulse the fall-off, only the riseing edge will smoothened. I do neither not see obviously what you have written wrong, having no access to 3.5 I cannot try.
But, my way, when defining functions like that is to make a "function" and plot that one, there are tools for that inside COMSOL, then start "simple" only with the modulo, then add next layer etc. mostly you see rapidly what is wrong.
I find that there is so many things to rememeber inside COMSOL Multiphysics, especially when you apply the latter, that yo uneed to fins "precedures" to get to your goal, that are generic, rather than remebering everything. So my "procedure" for functions like that is really to define them as "Functions" and test them individually.
Hope this can be of help on your way
Hi first of all, as you state there are several threads already about how to generate a pulse train, in v4 it has been made very easy with the "periodic" check box too and predefined pulse functions. One thing with your function, I do not see how you pulse the fall-off, only the riseing edge will smoothened. I do neither not see obviously what you have written wrong, having no access to 3.5 I cannot try. But, my way, when defining functions like that is to make a "function" and plot that one, there are tools for that inside COMSOL, then start "simple" only with the modulo, then add next layer etc. mostly you see rapidly what is wrong. I find that there is so many things to rememeber inside COMSOL Multiphysics, especially when you apply the latter, that yo uneed to fins "precedures" to get to your goal, that are generic, rather than remebering everything. So my "procedure" for functions like that is really to define them as "Functions" and test them individually. Hope this can be of help on your way -- Good luck Ivar
Posted: 1 decade ago 28.01.2011, 10:36 MEZ
That's very helpful!
Thank you for taking the time to answer.
I am just starting a final year project with comsol and am finding it a bit tricky to get the hang of.
That's very helpful! Thank you for taking the time to answer. I am just starting a final year project with comsol and am finding it a bit tricky to get the hang of.
Posted: 1 decade ago 05.04.2013, 19:56 MESZ
Hi Adam;
Have a nice day.
I just read you comments and posted messages about pulse train. What version are you using? because currently, I am also using mixed heaviside and modulo functions for periodic steeping of concentrations but I am with v3.5a.
My problem is the same as first posted message on the output of the functions. Do you have any idea on how to set up functions for this periodic stepping?
Thank you and have a great day.
Erwin
Hi Adam; Have a nice day. I just read you comments and posted messages about pulse train. What version are you using? because currently, I am also using mixed heaviside and modulo functions for periodic steeping of concentrations but I am with v3.5a. My problem is the same as first posted message on the output of the functions. Do you have any idea on how to set up functions for this periodic stepping? Thank you and have a great day. Erwin
