combining acoustic with laminar flow
Hi all,
did anybody simulated wind speed/direction impact on acoustic field?
combining laminar flow with pressure acoustics does not create multiphysics node.
Anybody have an idea?
Daria Wotzka
4 Replies Last Post 17.02.2017, 09:29 MEZ
Posted: 8 years ago 16.02.2017, 10:27 MEZ
Have you studies this application library example ?
www.comsol.eu/model/ultrasound-flow-meter-with-generic-time-of-flight-configuration-34991
Hi Have you studies this application library example ? https://www.comsol.eu/model/ultrasound-flow-meter-with-generic-time-of-flight-configuration-34991 -- Good luck Ivar
Posted: 8 years ago 16.02.2017, 10:35 MEZ
not yet :)
thanks a lot i will look on it.
best regards,
Daria
not yet :) thanks a lot i will look on it. best regards, Daria
Posted: 8 years ago 16.02.2017, 11:35 MEZ
Dear Ivar,
the >Ultrasound> is not available in the 5.2 :(
if I try with pressure acoustic would it be fine?
Daria Wotzka
Dear Ivar, the >Ultrasound> is not available in the 5.2 :( if I try with pressure acoustic would it be fine? -- Daria Wotzka
Posted: 8 years ago 17.02.2017, 09:29 MEZ
Hello
you are right its a new feature of 5.2a I see.
Normally you need the transport part that has been added to the Convected wave equation in 5.2a, you might write it out yourself, but there a quite some equations, probably its easier to upgrade if you have the cash ;(
I'm a happy user with a boss accepting to pay the maintenance and the upgrades. And at the speed COMSOL adds new features it's worth it, at least for an industrial approach.
Hello you are right its a new feature of 5.2a I see. Normally you need the transport part that has been added to the Convected wave equation in 5.2a, you might write it out yourself, but there a quite some equations, probably its easier to upgrade if you have the cash ;( I'm a happy user with a boss accepting to pay the maintenance and the upgrades. And at the speed COMSOL adds new features it's worth it, at least for an industrial approach. -- Good luck Ivar
