Designin narrow strip in the hinged part of cantilevercantilever in 3.5a
hi,
as im new to Comsol software i would like to know how to design a cantilever beam which has a narrow part at the fixed end and the rest is a normal rectangular beam. I would like to know the various steps that should be followed to design such cantilever.
Also i would like to know what are the mathematical parameters that can be found in Comsol software in terms of Biosensing.
I expect a favourable reply.
sandhya.
4 Replies Last Post 04.02.2011, 08:26 MEZ
Posted: 1 decade ago 03.02.2011, 11:51 MEZ
run the exercices and a few of the simple models, you will get then all the skills required to build such a model.
Comnsol has also excellent courses, worth wile to take once you start to get the grasp of the essentials.
Hi run the exercices and a few of the simple models, you will get then all the skills required to build such a model. Comnsol has also excellent courses, worth wile to take once you start to get the grasp of the essentials. -- Good luck Ivar
Posted: 1 decade ago 03.02.2011, 13:21 MEZ
is it possible to join two rectangular parts into one cantilever beam
Posted: 1 decade ago 03.02.2011, 19:29 MEZ
you should expalin a bit more, very many things are possible in COMSOL, some are easier than others
Hi you should expalin a bit more, very many things are possible in COMSOL, some are easier than others -- Good luck Ivar
Posted: 1 decade ago 04.02.2011, 08:26 MEZ
shall i attach my necessary structure for ur verification?
