modelling of wrap around gate using FEM in COMSOL
Posted 17.03.2017, 02:54 GMT-4 2 Replies
Hii
we are doing a project on "modelling of wrap around gate using FEM in COMSOL we found a few problems regarding the simulation.
Can somebody please help us with this.
we completed the part of geometry and assigning of the materials and analytic doping models, metal contacts and assigning the mesh with the reference of 2d characteristics of MOSFET
Thank you
Undefined variable.
- Variable: T
- Geometry: geom1
- Domain: 2
Failed to evaluate variable.
- Variable: comp1.semi.Nc
- Defined as: (((T/(unit_K_cf*300))^1.5)*28000000000000000000)/(unit_cm_cf^3)
- Expression: subst(comp1.semi.Nc,comp1.semi.Tl,comp1.semi.T0)
- Variable: comp1.semi.Nc_init
- Defined as: eps+subst(comp1.semi.Nc,comp1.semi.Tl,comp1.semi.T0)
- Variable: comp1.semi.ni_init
- Defined as: sqrt(comp1.semi.Nc_init*comp1.semi.Nv_init)*exp(((-0.5)*comp1.semi.Eg_init)/comp1.semi.Vth_init)
- Variable: comp1.semi.n_init
- Defined as: ((comp1.semi.Ndoping_init>=0)*((0.5*abs(comp1.semi.Ndoping_init))+sqrt(((0.5*comp1.semi.Ndoping_init)^2)+(comp1.semi.ni_init^2))))+(((comp1.semi.ni_init^2)*(comp1.semi.Ndoping_init<0))/((0.5*abs(comp1.semi.Ndoping_init))+sqrt(((0.5*comp1.semi.Ndoping_init)^2)+(comp1.semi.ni_init^2))))
- Variable: comp1.semi.V_init
- Defined as: (((comp1.semi.Vth_init*(((comp1.semi.Ndoping_init>=0)*log(comp1.semi.n_init/comp1.semi.ni_init))+((-log(comp1.semi.p_init/comp1.semi.ni_init))*(comp1.semi.Ndoping_init<0))))-comp1.semi.chi_init)-(comp1.semi.Eg_init*0.5))+((comp1.semi.Vth_init*0.5)*log(comp1.semi.Nv_init/comp1.semi.Nc_init))
- Expression: comp1.semi.V_init
- Feature: Dependent Variables 1 (sol1/v1)
Thank you
Undefined variable.
- Variable: T
- Geometry: geom1
- Domain: 2
2 Replies Last Post 18.03.2017, 01:37 GMT-4
