Turbulent pipe flow
Can i simulate the pipe flow with inlet and outlet pressure boundary condition ? I want pressure drop of 0.05-0.02 bar. I have used pref as 0 Pa.
I am simulating a pipe with dimension 6 mm diameter , 100 mm length.
which model would be better to use in single phase pipe flow?
Thank you
1 Reply Last Post 17.04.2017, 14:43 GMT-4
Posted: 9 years ago 17.04.2017, 14:43 GMT-4
First of all thank you so much for brief information.
now i understand the idea behind solving fluid flow in COMSOL.
But as you mentioned here about pressure drop, how can i set that boundary condition. Do i need to add pressure drop as pressure outlet bc ?
First of all thank you so much for brief information. now i understand the idea behind solving fluid flow in COMSOL. But as you mentioned here about pressure drop, how can i set that boundary condition. Do i need to add pressure drop as pressure outlet bc ?
