Matlab with Comsol
Posted 29.04.2017, 11:58 GMT-4 Interfacing, Studies & Solvers Version 5.2a 2 Replies
Hello everyone.
I am new to Comsol and Im trying to automate some measurements via matlab, by changing few parameters and exporting results to txt (from matlab), but i actually faced a problem on the begining. After loading a model and changing parameter i cant get a new solution (run procedure is not working).
Q. Do anyone know why this situation occured and have solution for it?
Here is the code :
model11 = mphload('path')
model11.param.set('wdef', '6[mm]');
% model11.study('std2').run;
model11.study('std2').run(); % i tried both methods and they dont work
mphplot(model11,'pg2')
model11.param.set('hdef', '2[mm]');
figure(2)
And there is a error :
Error using model1 (line 5)
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: java.lang.NullPointerException
Stack trace:
at com.comsol.model.selections.SelectionMethod.assocUpdate(SourceFile:1133)
at com.comsol.model.selections.LocalSelectionMethod.assocUpdate(SourceFile:55)
at com.comsol.model.internal.impl.SelectionImpl.assocUpdateThis(SourceFile:1152)
at com.comsol.model.method.ModelEntityMethod.assocUpdate(SourceFile:900)
at com.comsol.model.method.ModelEntityMethod.assocUpdate(SourceFile:895)
at com.comsol.model.method.GeomSequenceMethod.updateSelectionsAfterFinGeomChange(SourceFile:200)
at com.comsol.model.internal.impl.GeomSequenceImpl.updateSelectionsAfterFinGeomChange(SourceFile:4357)
at com.comsol.model.method.GeomSequenceMethod.setGeomAndAssoc(SourceFile:2478)
at com.comsol.model.internal.impl.GeomSequenceImpl.a(SourceFile:4349)
at com.comsol.model.internal.impl.GeomSequenceImpl.setGeomAndAssoc(SourceFile:3541)
at com.comsol.model.method.GeomSequenceMethod.setGeomFromLastActiveFeature(SourceFile:2497)
at com.comsol.model.method.GeomSequenceMethod.build(SourceFile:1956)
at com.comsol.model.method.GeomSequenceMethod.b(SourceFile:1827)
at com.comsol.model.method.GeomSequenceMethod.run(SourceFile:1748)
at com.comsol.model.internal.impl.GeomSequenceImpl.ap(SourceFile:4099)
at com.comsol.model.internal.impl.GeomSequenceImpl.run(SourceFile:3236)
at com.comsol.model.method.ModelMethod.multiphysics(SourceFile:927)
at com.comsol.model.internal.impl.ModelImpl.a(SourceFile:4826)
at com.comsol.model.internal.impl.ModelImpl.multiphysics(SourceFile:4078)
at com.comsol.model.method.SolverSequenceMethod.doCreateAutoSequence(SourceFile:2432)
at com.comsol.model.internal.impl.SolverSequenceImpl.k(SourceFile:3792)
at com.comsol.model.internal.impl.SolverSequenceImpl.createAutoSequence(SourceFile:984)
at com.comsol.model.method.StudyMethod.b(SourceFile:333)
at com.comsol.model.method.StudyMethod.doCreateAutoSequences(SourceFile:228)
at com.comsol.model.method.StudyMethod.doRun(SourceFile:51)
at com.comsol.model.internal.impl.StudyImpl.c(SourceFile:349)
at com.comsol.model.internal.impl.StudyImpl.a(SourceFile:348)
at com.comsol.model.internal.impl.StudyImpl$1.a(SourceFile:328)
at com.comsol.model.internal.impl.StudyImpl$1.execute(SourceFile:1)
at com.comsol.model.clientserver.ClientManager$1.call(SourceFile:169)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
I would be grateful, if someone can help me with this issue.
Here is the code :
figure(2)
Exception:
Stack trace:
2 Replies Last Post 02.05.2017, 07:32 GMT-4
