Pair thermal contact
Posted 25.05.2017, 14:37 GMT-4 Heat Transfer & Phase Change Version 5.2 0 Replies
I want to use pair thermal contact as a boundary condition for two surfaces that one of them has high temperature and moves toward the other surface until to be in contact and the second surface is at room temperature. But I cannot define the separate temperatures for these two surfaces with "Pair thermal contact", how can I do this? my geometry has two rectangles that the bottom side of the upper rectangle touches the upper side of the bottom rectangle. Also in the initial temperature, I cannot set different temperatures for these two domains.
I will appreciate if you help me with this.
Hello Zahra Kanani Aghkand
