Hydrodynamic focusing model appears to have excessive diffusion
Posted 15.06.2017, 20:38 MESZ Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics Version 5.2a 0 Replies
From imaging of the actual device with the same flow rates, I know the sample beam profile is more defined, and separate flows are maintained throughout the device with very little mixing (this is also visualized in the model used by the paper above).
However, in my model, my sample substance appears to completely diffuse into the surrounding water sheath flow, and it is completely mixed into the sheath flow by the outlet. This result is not what I anticipated, nor is it what I have observed.
The file for my model can be found here: drive.google.com/open?id=0B8p0w5pyDH5eTm5vN3NYVWFQUlk
I appreciate any help!
Hello Chloe Yang
