Computing flux in conduction convection module
Posted 02.03.2011, 14:47 MEZ Heat Transfer & Phase Change Version 3.5a 2 Replies
Hi everybody,
I'm facing a quite anoying problem.
In the model i've attached to this post i cannot find the flux through outer boundaries equal to the integration over a subdomain of the heat source.
First attempt : subdomain 4
On one side i calculate the integration over a subdomain 4 of Q_cc
On the other side i calculate every ntflux_T_cc on every outer boundaries of the subdomain 4.
The result is not good and i cannot understand why ?
Second attempt : I want to extend this to a bigger domain : the domain made of domains 2 and 4
On one side i calculate the integration over a subdomains (subdomain 2 and 4) of Q_cc
On the other side i calculate every ntflux_T_cc on every outer boundaries of the subdomain formed by subdomain 2 and 4.
It probably comes from the computation of the flux on the boundary 4 and 21.
I've paid attention to the signs of the normal flux.
I've check the mesh dependancy and it's independant.
I've tried the lagrange multiplers by i'm not so familiar with this.
I've tried the reactf method but not succes with this too.
Do someone has already solved that sort of problem ?
Thanks a lot for your help.
Thomas
Thomas
2 Replies Last Post 02.03.2011, 17:05 MEZ
