Strange error
Hi all
What does this mean?
Only one thread allowed.
Old model cannot be reconstructed. Do Clear Solution to expunge
5 Replies Last Post 06.11.2012, 08:03 GMT-5
Hello Muhale Mutshena
Dulakshi Karunasinghe
Posted: 1 decade ago 27.02.2012, 22:04 GMT-5
Did you find a solution for this? I too get the same error.
Posted: 1 decade ago 28.02.2012, 01:20 GMT-5
try a EDIT clear all solution Edit Clear Mesh, File Reset Model, save, reopen COMSOl clean and reload your file. This might do the trick
Hi try a EDIT clear all solution Edit Clear Mesh, File Reset Model, save, reopen COMSOl clean and reload your file. This might do the trick -- Good luck Ivar
Posted: 1 decade ago 28.02.2012, 13:31 GMT-5
Hi Ivar, i have the same problem, but with your answer I erased the solution, so, this is not the best way to solve this problem...another idea?
Posted: 1 decade ago 29.02.2012, 00:52 GMT-5
sorry to hea that, but indeed if you delete a solver you delete the related nodes lower down. The best would be to use a newer veersion of COMSOL 4.0 was really the firs out in the new "costume", the stability of the programme has greatly improved since
Hi sorry to hea that, but indeed if you delete a solver you delete the related nodes lower down. The best would be to use a newer veersion of COMSOL 4.0 was really the firs out in the new "costume", the stability of the programme has greatly improved since -- Good luck Ivar
Posted: 1 decade ago 06.11.2012, 08:03 GMT-5
Hi all,
it happened after i copy comsol model 4.2 (incl. solution) to another directory.
i'm not sure about it but it can be "reproduced" or "repaired" by send that model to comsol support via some ftp link.
regards
akmal
Hi all, it happened after i copy comsol model 4.2 (incl. solution) to another directory. i'm not sure about it but it can be "reproduced" or "repaired" by send that model to comsol support via some ftp link. regards akmal
