Use of moving wall in COMSOL?
I'm trying to simulate a rigid object moving in a rigid fluid-filled channel in COMSOL. The inlet provides a velocity for the non-compressible fluid, which pushes the object. No problem so far, this works fine for time-dependent studies in 2D.
The issue is that I want to move to 3D, and I think that will become very computationally expensive. It was suggested that I use snapshots of static studies (it's Stokes flow, so supposedly that's ok -- regardless, that's a different issue), rather than doing time-dependent studies. But, a static study won't converge (which makes sense because there is no steady state given the continuous movement of the object down the channel).
I was told the solution to this was to use a moving wall. I have spent hours trying to figure out how to do this, and learned nearly nothing. The 1000+ page COMSOL reference guide has one paragraph on moving walls, and essentially says "If you use a moving wall, u = u sub w." Not very informative.
I would greatly appreciate it if someone could explain the theory of a moving wall in general (why and when is it used), and how it applies to this problem specifically (where does the wall go, and what are the parameters).
Thank you!
0 Replies Last Post 22.08.2017, 19:26 MESZ
Hello Thomas Brian
