Import Data and Interpolation
Hello all,
I need to import data from an .txt file. I used an interpolation function, because it appears that it is the only way to do so. But interpolated data with a linear interpolation are not the same as the ones I wanted to import.
I work under COMSOL V5.2 on the acoustical/frequency domain study.
I need to import data : impedance = f(frequency)); and put them as a impedance boundary during my calculation. The calculation is done for frequencies in range(10,1,8000) and I need the impedance boundary value to change at each frequency step.
It appears that, because of the interpolation, my interpolated impedance values are not the same as the one I import.
I interpolated the impedance data from a table named imp.txt (which contains two columns "freq impedance") with a frequency step of 1Hz from 10Hz to 8000Hz :
10 4.23
11 5.48
12 6.45
8000 7.12
and used a linear interpolation and a constant extrapolation.
When I plot the imported data (in a table under Results tab, from the same imp.txt file) and the interpolated ones, the curves don't fit.
I don't know how the interpolation choose its own abscisses and it seems I can't control it ?
Thank you for your help !
Marie
0 Replies Last Post 11.09.2017, 13:31 MESZ
Hello Marie Jeanneteau
