ODE: dI1/dt and dI2/dt appear in the only same equation
Posted 23.10.2017, 13:52 MESZ Low-Frequency Electromagnetics, General Version 5.2a 3 Replies
In the picture, I1, I2 and U are variables. I1 is the excitation of mf.VCoil_1 while I2 is the excitation of mf.VCoil_2. Coil1 and Coil2 are solved in the same solution domain.
The question is that, the equations can be solved from the perspective of the circuit. However, since dI1/dt and dI2/dt appear in the only same equation, I don't know how to write the equations in ODE, or if there is anther way to describe this set of circuit equations (without using the circuit physical field, there is no thyristor model in the physical field). Hoping someone can answer for me, grateful!
