Coupling magnetic fields module with General PDE module
Posted 27.10.2017, 07:34 GMT-4 Low-Frequency Electromagnetics, Studies & Solvers Version 5.0 0 Replies
In the project, I have a 2D axisymmetric model of a magnet levitating over a superconductor. The magnet is described using the Magnetic Field module where the remanent flux density is defined. The superconductor is described by solving the H-formulation using the General PDE module. The magnetic field from the magnet is solved as the first step and that magnetic field is used for the second step which solves for the H in the superconductor.
However, whenever I run the program, it shows an error, "Failed to find consistent initial values. Last time step is not converged."
Can someone help me figure out why this is happening? Thanking you in advance
Hello Shreyam Natani
