Meshing Thin Dialectric in Air
Posted 16.11.2017, 20:13 GMT-5 Low-Frequency Electromagnetics, Mesh Version 5.2a 2 Replies
Hi All,
New Comsol user here. I want to model the electric field in and around a thin dialectric (0.3um) sandwhiched between two conductive plates (3x60um) of thickness ~30um each in an air box. To get good resolution in the dialectric I swept it, dividing it into 5 layers. The air box cannot be swept and it gives an error when I apply a tetrahedral mesh because of the rectangular mesh on the sides of the dialectric (in contact with the air) created by the sweep. Meshing the entire model using the "Extremely Fine" mesh produces a mesh two tetrahedrals tall in the oxide which is not fine enough.
Is there a way I can sweep the dialectric while applying a tetrahedral mesh to the air, get finer resolution in the dialectric with a tetrahedral mesh or is there something I haven't considdered.
-------------------Khurram Tai
