64 pipes in comsol
I've been trying to mesh 64 little straight pipes with comsol 4.1. The pipes are surrounded by air and they produce 64 different heats. My problem is when I use the comsol default meshing (physics dependent) there is an error, so I changed my way and try to mesh the pipes by using the Free triangular and sweept tools. I've get good results for the pipes however when I try to mesh the surrounding air a new error happens.
Any idea about how to mesh this problem?
Thank you in advance.
2 Replies Last Post 31.03.2011, 10:19 MESZ
Posted: 1 decade ago 29.03.2011, 21:36 MESZ
is the air a cylinder ? if so, have you tried to mesh the pipes and the air in one go (sweep) ?
Or I can suggest that you divide the tube lengths by an equal number of elements along the cut line, to have/help the mesh sweep along the full geometry in a continuous way
Hi is the air a cylinder ? if so, have you tried to mesh the pipes and the air in one go (sweep) ? Or I can suggest that you divide the tube lengths by an equal number of elements along the cut line, to have/help the mesh sweep along the full geometry in a continuous way -- Good luck Ivar
Posted: 1 decade ago 31.03.2011, 10:19 MESZ
Hi.
Good idea!!
Thank you!
Hi. Good idea!! Thank you!
