Accessing a pre-existing model node from MATLAB
Hello!
I have created a model using the Comsol interface which automatically generates a geometry node (by default, "Geometry 1"). Using MATLAB I wish to add the entity c1 (see below) to the "Geometry 1" node but I receive the following error message: "Undefined variable "geom1" or class "geom1.feature.create"."
My code is:
model.component('comp1').geom('geom1').lengthUnit('mm');
c1 = geom1.feature.create('c1','Circle'); c1.set('r',Ro); c1.set('pos',[0 0]);
Thank you in advance.
1 Reply Last Post 21.12.2017, 03:38 GMT-5
Posted: 8 years ago 21.12.2017, 03:38 GMT-5
Hi André
You can either do
c1 = Model.geom('geom1').feature.create('c1','Circle'); c1.set('r',Ro); c1.set('pos',[0 0]);
or
geom1 = Model.geom('geom1'); c1 = geom1.feature.create('c1','Circle'); c1.set('r',Ro); c1.set('pos',[0 0]);
Lars Gregersen
Comsol Denmark
Hi André You can either do c1 = Model.geom('geom1').feature.create('c1','Circle'); c1.set('r',Ro); c1.set('pos',[0 0]); or geom1 = Model.geom('geom1'); c1 = geom1.feature.create('c1','Circle'); c1.set('r',Ro); c1.set('pos',[0 0]);
