Vary a parameter non-linearly with time
Posted 04.04.2011, 10:53 GMT-4 Low-Frequency Electromagnetics, Studies & Solvers 10 Replies
I want to vary a parameter (Voltage) polynomially in time.
So i would like to have:
V(t) = a*t^6 + b*t^5 + ... + c*t + d
The problem is that COMSOL keeps the units from the variable t so my expression ends up with inconsistent units and i am not permitted to use it.
Is there anyway i can extract the value of t at each step in the solver and use it numerically without its units?
Kind regards,
Dom.
Thanks.
Unit issues are warnings, COMSOL continues to calculate and it's correct if you use the correct values.
then its "easy" either you define the units of your "constants a*t^6 as a[V/s^6]*t or a*(t[1/s])^6 the latter gives you a unitless result, you you might need to add a *1[V] where you use it.
I have to vary the radius of a circle with time sinusoidally. When I did it by defining 'radius' as a function of sine in 'Parameters' section, I got an error message 'Unknown model parameter t'. I tried to resolve this issue by explicitly defining a parameter 'T' using range function. But then it shows 'Failed to evaluate expression; Function: Range'..I also tried to define 'radius' as a variable but got an error.
Kindly guide me on how to define time varying radius parameter of a circle or more generally time varying parameters which represent geometrical figure dimensions.
Regards
Ankit Gupta
Regards
Ankit Gupta
By the way, I read in another thread that you don't actually work for COMSOL, and you are giving all this help out of the goodness of your heart. If this is true you are a hero. Even if it's not you're still damn helpful.
Kind regards.
Dom.
indeed I'm not from COMSOL, neither not any hero ;)
but as physicist I would like to see more physics trained people out here, and COMSOL is such a good tool to illustrate physics ...
And anyhow, one always harvest something from "giving out", it's just that one must be prepared to give more than what one receive, but that is always like that, another way of testing entropy ;)
Need you help..
Kindly guide me on how to define time varying radius parameter of a circle or more generally time varying parameters which represent geometrical figure dimensions. I am using Version 4.1..Kindly help me.
Regards
Ankit Gupta
t the time is only defined if you are using a transient solver, and only once started. I usually add a Parameter t=0[s] even when using a transient solver to avoid error messages during model build up.
Then you must distinguish Parameter and Variable. A Parameter (Constant in v3.5) is read once at programme start, but it can be overwritten by a COMSOL variable later on. A Variable is expected to change as the solver advances (might not but then its better to define it as a Parameter. Global variables are not implicitly depending on x,y,z, (t ? not sure), while model variables might, and might even have different definition per entity.
What follows is writing out my thought, but these ideas needs to be tested as I see I'm stuck, not sure what to propose, would have to test it out :) But I'm sure you could too
So define your R0 and Ra initial radius and amplitude variation of radius as Parameters and then either define a Variable or write directly in the circle radius field
Next issue if you call a transient solver I'm not sure the geometry is updated ? (I would have to test it out too myself)
One way is to use the deformed geometry physics DG
Another way to get the geometry updated is to use explicitly an explicit Parametric sweep. Normally you do not use "t" as parameter, but one could, then one need to call the transient solver with only one time
Next issue this that an external Parametric sweep like that normally restarts from initial conditions default all = "0" not the best approach.
Hope I didn't confuse you fully, but you need to try it out, as I do not have a simple straight answer, not sure what to propose as quickest ;)
I'll get back to you after trying these suggestions.
Regards
Ankit Gupta
Thank Ivar - this has solved my problem.
Kind regards.
Dom.
Ivar is a living legend to all of us.
