Save a solution
I am running some simulation on COMSOL4.1 and I have a question.
How can I save the results and the graphs of one simulation?
For example, I run a simulation with some parameters and boundary conditions. I have a result and some graphs.
Then if I run an other simulation with different parameters and boundary conditions, I will lose my previous results and graphs.
Is there a way to save the results for each simulation?
Thank you
Francois
2 Replies Last Post 18.04.2011, 13:03 MESZ
Posted: 1 decade ago 18.04.2011, 12:00 MESZ
you can right click a plot group node and save as image (or as txt file), you will then get a node in the Repot section where you add the file name and you exectute by a "store" (icomn upper right side of node GUI border. In this way it is recorded so you can repeat in one click next time: NOTE the file names remain so they would be overwritten
You can also save a graph manually in the graphics view hit the "camera " icon also upper right border of the graphics window GUI
Hi you can right click a plot group node and save as image (or as txt file), you will then get a node in the Repot section where you add the file name and you exectute by a "store" (icomn upper right side of node GUI border. In this way it is recorded so you can repeat in one click next time: NOTE the file names remain so they would be overwritten You can also save a graph manually in the graphics view hit the "camera " icon also upper right border of the graphics window GUI -- Good luck Ivar
Posted: 1 decade ago 18.04.2011, 13:03 MESZ
Thank you for your help.
Francois
Thank you for your help. Regards, Francois
