Time-step chosen by BDF method?
The time-dependent solver chooses an extremely small time-step, and I can't find how this time-step is chosen.
Any guess?
All what I found is :
"IDA [...] uses variable-order variable-step-size backward differentiation formulas (BDF)."
p 365 Reference Guide
Thank you very much for your help.
Guillermo Vilaplana
2 Replies Last Post 28.04.2011, 22:25 MESZ
Posted: 1 decade ago 28.04.2011, 21:16 MESZ
If you want to controle it instead:
Under Study ->SolverConfiguration -> Solver x -> Time-Dependent solver x
Time Stepping Tab.
If you want to controle it instead: Under Study ->SolverConfiguration -> Solver x -> Time-Dependent solver x Time Stepping Tab.
Posted: 1 decade ago 28.04.2011, 22:25 MESZ
The time stepper often starts with small steps, as often we are lazy and leave "0" as initial conditions, but true current, or heat flux starting far away from "0" so the system believes its facing a large derivative at the beginning of the transient solver sequence, hence small steps. use better initial conditions with smooth transitions and your solver will converge quicker
Hi The time stepper often starts with small steps, as often we are lazy and leave "0" as initial conditions, but true current, or heat flux starting far away from "0" so the system believes its facing a large derivative at the beginning of the transient solver sequence, hence small steps. use better initial conditions with smooth transitions and your solver will converge quicker -- Good luck Ivar
