How to use material properties in PDE depending on domain?
Hi.
I've been working on this problem for months now and can find no solution on the forums or in the knowledge base.
In Comsol 4.1(.0.185)
Let's say I want to solve the heat transfer equation using the general form PDE interface.
Then I need the material properties k, Cp and rho.
I can easily get those into my formulas using mat1.def.rho, mat2.def.Cp, mat64.def.k11 and so on, but that's only for one material at a time.
How can I get the actual active material?
Of course, I could add a new General Form PDE node for each domain of the model, but that soon gets ugly and really hard to maintain when the number of materials grow.
Best regards
/ Thomas
Edit: Ps. Previewing a message before posting seem to remove all selected Topics... A bug?
7 Replies Last Post 10.05.2011, 22:30 MESZ
Posted: 1 decade ago 10.05.2011, 11:35 MESZ
example for k.
on the Domain setting instead of using k from material, chose user defined: k1
and define k1 as a global parameter.
the on Study right click, and add parameter sweep. add k1, and give the value of k1: 0 1 2 3
means: the stationary simulation will be repeat for each k1-value. you cannot input 1 2 3 1, smaller value are not allowed. i'm sure that you can find info about it on documentation
if you have k1, rho1 and cp1
paremeter value: 1 100 3000 2 200 4000
means: 1st sweep --> k1=1 rho1=100 cp1=3000
2nd sweep --> k1=2 rho1=200 cp1=4000
i hope it can help you.
regards
akmal hidayat
Hi, example for k. on the Domain setting instead of using k from material, chose user defined: k1 and define k1 as a global parameter. the on Study right click, and add parameter sweep. add k1, and give the value of k1: 0 1 2 3 means: the stationary simulation will be repeat for each k1-value. you cannot input 1 2 3 1, smaller value are not allowed. i'm sure that you can find info about it on documentation if you have k1, rho1 and cp1 paremeter value: 1 100 3000 2 200 4000 means: 1st sweep --> k1=1 rho1=100 cp1=3000 2nd sweep --> k1=2 rho1=200 cp1=4000 i hope it can help you. regards akmal hidayat
Posted: 1 decade ago 10.05.2011, 12:08 MESZ
Thanks for your reply, but I think you misunderstood my question.
What I have is a model with a number of domains, say like a piece of metal in air.
I want to use the same equation in both domains, but they obviously have different properties.
So far, the only way I have found to do this is to define two separate but almost identical functions, each valid in only one domain.
I think that with the materials library and everything, there really should be a cleaner way of doing this.
Thanks for your reply, but I think you misunderstood my question. What I have is a model with a number of domains, say like a piece of metal in air. I want to use the same equation in both domains, but they obviously have different properties. So far, the only way I have found to do this is to define two separate but almost identical functions, each valid in only one domain. I think that with the materials library and everything, there really should be a cleaner way of doing this.
Posted: 1 decade ago 10.05.2011, 14:08 MESZ
Under Model->Definitions add two (or more) variable nodes.
Change the geometric entity level to "Domain" and select a different domain for the two Variable nodes. Define as many variables as you like in the table in the Variables section.
Lars Gregersen
Comsol Denmark
Under Model->Definitions add two (or more) variable nodes. Change the geometric entity level to "Domain" and select a different domain for the two Variable nodes. Define as many variables as you like in the table in the Variables section. Lars Gregersen Comsol Denmark
Posted: 1 decade ago 10.05.2011, 16:15 MESZ
Not quite what I was hoping for, but it does work well enough.
Thank you!
Perhaps we can hope for a better connection between materials and mathematical interfaces in 4.3...
Not quite what I was hoping for, but it does work well enough. Thank you! Perhaps we can hope for a better connection between materials and mathematical interfaces in 4.3...
Posted: 1 decade ago 10.05.2011, 20:04 MESZ
there is something I do not understand fully in your question.
Material properties you can define them as your own defined "Parameters" and enter them directly into the "user defined" fields,
Or you can define them on Entities = domains, respectively boundaries, edges or points under the material node.
Thereafter you can access them directly with their names such as "rho" in a i.e. domain or boundary field, and COMSOL will catch the relevant index matching from the material node and use the correct ones.
If you are working with the mat1.... etc tag names, then you are accessing directly the material nodes in the original order (via tag names) they where entered (and edited). You loose all the indexing taken care of by COMSOL and you do not need strictly use the relation of which material is attached to which domain, respectively boundary (whatever applies).
One thing, if you apply a material to a domain (volume in 3D) i.e. steel, then you need to redefine a "steel2" that applies to the "Boundaries = surfaces in 3D) if you define also material physics on the boundary. As by default in COMSOL the boundaries do NOT heritage the domain material properties, particularly because in "union" mode, you have a common boundary for two adjacent domains, so COMSOL cannot choose by itself which of the two materials to set on the common boundary between the two materials.
It took me some time to understand all this, but once understood, I find it rather logical
Hi there is something I do not understand fully in your question. Material properties you can define them as your own defined "Parameters" and enter them directly into the "user defined" fields, Or you can define them on Entities = domains, respectively boundaries, edges or points under the material node. Thereafter you can access them directly with their names such as "rho" in a i.e. domain or boundary field, and COMSOL will catch the relevant index matching from the material node and use the correct ones. If you are working with the mat1.... etc tag names, then you are accessing directly the material nodes in the original order (via tag names) they where entered (and edited). You loose all the indexing taken care of by COMSOL and you do not need strictly use the relation of which material is attached to which domain, respectively boundary (whatever applies). One thing, if you apply a material to a domain (volume in 3D) i.e. steel, then you need to redefine a "steel2" that applies to the "Boundaries = surfaces in 3D) if you define also material physics on the boundary. As by default in COMSOL the boundaries do NOT heritage the domain material properties, particularly because in "union" mode, you have a common boundary for two adjacent domains, so COMSOL cannot choose by itself which of the two materials to set on the common boundary between the two materials. It took me some time to understand all this, but once understood, I find it rather logical -- Good luck Ivar
Posted: 1 decade ago 10.05.2011, 21:45 MESZ
Thank you, but this is only true for the predefined physics interfaces and not the PDE interface.
Also, even in the predefined interfaces I imagine it works only for material properties normally used by the interface, so you can't for example access the Cp property of a material in a electric currents interface - why ever you would want to do that.
Which is exactly the problem...
[QUOTE] ... Material properties you can define them as your own defined "Parameters" and enter them directly into the "user defined" fields, ... [/QUOTE] Thank you, but this is only true for the predefined physics interfaces and not the PDE interface. Also, even in the predefined interfaces I imagine it works only for material properties normally used by the interface, so you can't for example access the Cp property of a material in a electric currents interface - why ever you would want to do that. [QUOTE] ... If you are working with the mat1.... etc tag names, then you are accessing directly the material nodes in the original order (via tag names) they where entered (and edited). You loose all the indexing taken care of by COMSOL and you do not need strictly use the relation of which material is attached to which domain, respectively boundary (whatever applies). ... [/QUOTE] Which is exactly the problem...
Posted: 1 decade ago 10.05.2011, 22:30 MESZ
OK I now got your point. I was fooled by the fact that I could define linked materials, and properties related, but didn't notice at once they were not active in the PDE environment.
This might be corrected in V4.2, will see soon, if not, I would suggest that you propose it as a "suggestion" to support, I believe too its a valid point, and they do listen to us ;)
Hi OK I now got your point. I was fooled by the fact that I could define linked materials, and properties related, but didn't notice at once they were not active in the PDE environment. This might be corrected in V4.2, will see soon, if not, I would suggest that you propose it as a "suggestion" to support, I believe too its a valid point, and they do listen to us ;) -- Good luck Ivar
