Possible Inconsistency Between mpheval and mphmatrix?
Posted 12.05.2011, 02:23 MESZ Interfacing Version 4.1 1 Reply
>> model = mphload('mcbee15.mph');
>> dat=mpheval(model, {'x' 'y' 'T'});
>> solution=mphgetu(model);
I then compare the node 'x' value (col 1), the node 'y' value (col 2), and the node 'T' value (col 3) as given to me by the mpheval command. Column 4 is the output of 'T' from the mphgetu command. I expected columns 3 and 4 to match up perfectly, but they are completely different permutations of the same 'T' values.
>> [dat.d1',dat.d2',dat.d3',solution]
ans =
0.7500 0 1.0000 1.0000
1.0000 0 1.0000 0.8621
0.7500 0.2500 0.8621 0.7453
1.0000 0.2500 0.8621 0.6672
0.7500 0.5000 0.7453 0.6398
1.0000 0.5000 0.7453 1.0000
0.7500 0.7500 0.6672 1.0000
1.0000 0.7500 0.6672 1.0000
0.7500 1.0000 0.6398 1.0000
1.0000 1.0000 0.6398 0.8621
0.5000 0 1.0000 0.7453
0.5000 0.2500 0.8621 0.6672
0.2500 0 1.0000 0.6398
0.2500 0.2500 0.8621 0.8621
0 0 1.0000 0.8621
0.5000 0.7500 0.6672 0.7453
0.5000 1.0000 0.6398 0.6672
0.2500 0.5000 0.7453 0.7453
0.2500 0.7500 0.6672 0.7453
0.2500 1.0000 0.6398 0.6672
0 0.7500 0.6672 0.6398
0.5000 0.5000 0.7453 0.6398
Can anyone please explain the discrepancy? Also, which one of these would represent the coefficient vector that would be pre multiplied by the non-reduced stiffness matrix? Does dat.p truely give me the x,y coordinates of each node or am I missing something?
Thanks much!
Hello Brian McBee
