Importing STL files
I'd like to import an stl file into a COMSOL simulation, and the online tutorial says that COMSOL supports this file type. However, when I try to use the import function on the Geometry toolbar, the file types that COMSOL gives me the option to import are Mesh, COMSOL Multiphysics file, and DXF file. When I browse for the stl file I want to import, I can't find it where it's saved. Any help in changing the COMSOL settings to be compatible with this file type would be appreciated.
Thanks, Henry
2 Replies Last Post 04.07.2018, 19:48 MESZ
Posted: 7 years ago 03.07.2018, 23:22 MESZ
Could it be that you are in a 2Dgeometry as opposed to a 3D one?
Jeff Hiller
Could it be that you are in a 2Dgeometry as opposed to a 3D one? Jeff
Posted: 7 years ago 04.07.2018, 19:48 MESZ
Hi Jeff,
That is the problem, thank you for your help.
-Henry
Hi Jeff, That is the problem, thank you for your help. -Henry
