surface numbering or geometric entity numbering
Does COMSOL 4.x display surface numbers or geometric entity (boundaries, domains etc) numbers on the screen?
I am asking because inorder to make boundary selection, I am having to select all the boundaries and eliminate the ones that I don't need. But if I can see the numbering of the boundaries on the screen then I can enter the numbers directly. So is there a way to display the numbers assigned to each entity/boundary?
Sirisha
2 Replies Last Post 17.05.2011, 00:14 MESZ
Posted: 1 decade ago 14.05.2011, 09:14 MESZ
in the view node, you have different options, you an also add new views, so its worth to explore the "right click" in this region too ;)
Hi in the view node, you have different options, you an also add new views, so its worth to explore the "right click" in this region too ;) -- Good luck Ivar
Posted: 1 decade ago 17.05.2011, 00:14 MESZ
Thanks Ivar!
Sirisha
Thanks Ivar! Sirisha
