Temperature dependent variables - Circular variable dependency detected.
Hello folks,
I would like to define some temperature-dependent variables in my model. I defined them under "Global definitions - variables". So Comsol shall calculate for each time step the variable with the current temperature.
For example:
Expression: 500*T - 200 [Pa]
I thought, that Comsol know that he has to use the temperature for "T", but I got an error message:
- Variable: T
- Geometry: 1
- Domain: 1
Can anyone help me?
Greetings.
3 Replies Last Post 22.06.2011, 21:47 GMT-4
Posted: 1 decade ago 18.05.2011, 22:25 GMT-4
Try this:
(500*mod1.T[1/K]-200)[Pa]
[1/K] is there to cancel the units of temperature.
Hi, Try this: (500*mod1.T[1/K]-200)[Pa] [1/K] is there to cancel the units of temperature.
Posted: 1 decade ago 19.05.2011, 03:08 GMT-4
Thx, thats it. :)
Thx, thats it. :)
Posted: 1 decade ago 22.06.2011, 21:47 GMT-4
Since you are defining a global variable, you should point to the model to which it belongs. In your case, T is the dependent variable for model 1 (your only model I presume), that is why calling this variable requires: mod1.T, where mod1 is your model's identifier.
If the same variable is used in a subdomain field (variables under model 1), you could ommit the pointer mod1 and just use the variable T
Regards
Ali
Hi, Since you are defining a global variable, you should point to the model to which it belongs. In your case, T is the dependent variable for model 1 (your only model I presume), that is why calling this variable requires: mod1.T, where mod1 is your model's identifier. If the same variable is used in a subdomain field (variables under model 1), you could ommit the pointer mod1 and just use the variable T Regards -- Ali
