19.05.2011, 17:44 MESZ
Hi Isabel,
yes, in case you want harmonic excitation you can use the frequency domain study, if your excitation is non-harmonic you would use the transient study and define a current density as a function of time.
Cheers
Edgar
Hi Isabel,
Cheers
Edgar
19.05.2011, 17:59 MESZ
Hi Edgar,
thank-you for your answer.
I would like to have an External Current Density in "c1" of "A*sin(time)", where "A" is a constant but I don't know how to introduce the function of time.
Could you help me?
Thanks in advance.
Isa
Hi Edgar,
Could you help me?
Thanks in advance.
Isa
20.05.2011, 09:33 MESZ
Isa,
if your external current density is a sine wave you can use frequency domain and there is no need to define a function of time unless you want to study the instationary build up of the oscillation. Frequency domain gives you the stationary situation after long times.
Just define the current density on the boundary and the frequency or a range of frequencies in the frequency domain study node.
If you really want a transient study you define your funtion in the model or global definitions. The internal variable for time is 't', so the sine wave looks like c1 = A*sin(t). I guess you have an angular frequency omega too, so it becomes c1 = A*sin(omega*t).
I would recommend not to use simple variable names like A or c1, because they may be occupied by COMSOL.
Cheers
Edgar
Isa,
Cheers
Edgar
20.05.2011, 10:35 MESZ
Dear Edgar,
Then, as I am interested in a stationary solution, I decide to use frequency domain.
So, if I want to use f=50Hz (for example).
In External Current Density, I would set:
Je=Amplitude*sin(2*pi*freq) [A/m^2]
But as this variable "freq" has the value of 50Hz, Je=0, so...
Or perhaps I should set simply Je=Amplitude [A/m^2].
Moreover, you talk about define the current density on the boundary and the frequency or a range of frequencies in the frequency domain study node, but I would like to define the current density on the total circule that represent the coil1.
Could you help with this?
Thanks again in advance.
Isa
Dear Edgar,
Isa
20.05.2011, 11:18 MESZ
Isa,
yes, you define the current density on your circular coil domain, not a boundary. This was my error.
The current density is just the amplitude, you don't need the sine function because this is the time dependent part that is not needed for frequency domain.
Cheers
Edgar
Isa,
Cheers
Edgar
20.05.2011, 13:53 MESZ
Thank-you very much!
Isa
Isa
