Create a mesh with disproportionnal object
Hello everybody,
I'm working on a micro-structure with these dimensions : 2000µm (x) / 2000µm (y) / 1µm (z) and the problem is that I don't know how to create a good mesh to have a good volume resolution without 1 million elements
3 Replies Last Post 07.06.2011, 17:23 MESZ
Posted: 1 decade ago 07.06.2011, 17:01 MESZ
Have you tried sweep meshing? See User's Guide, Chapter 17.
Posted: 1 decade ago 07.06.2011, 17:13 MESZ
Yes I have tried a swept mesh, in all directions, and I'm always around zero in quality
Posted: 1 decade ago 07.06.2011, 17:23 MESZ
Given how the quality factor is defined, i.e. purely based on geometric considerations, that's expected and in fact it's the whole point of using a swept mesh here: you are trying to create elements that are elongated in a manner similar to your geometry. The real question is whether the mesh is able to capture the physics. If it is, then the quality of the mesh can be low, especially if you use a direct solver (iterative solvers might complain about ill-conditioning - that depends on your physics of course).
