Rotation angles for SC-cut
I try to simulate a SC-cut quartz resonator.
I use the "Rotation angle method" in the "Coordinate system settings" window to define the orientation but I am a bit confused about the consecutive angles. Should I write 34(x) | 0(y) | 22(z) or -34 | 0 | -22?
Thanks for your help.
Alexandre
3 Replies Last Post 13.12.2012, 10:16 MEZ
Posted: 1 decade ago 14.06.2011, 22:39 MESZ
try the coordiante plot possibilities to see the final coordinate orientation. YOu need to at least load your initial conditions to get the plot polulated (no need for a full solve)
Oups sorry that applies for V4, in 3.5 its a pain to check ;), I usually defined a force vector along x,y,z in the new coordinate and checked its direction
Hi try the coordiante plot possibilities to see the final coordinate orientation. YOu need to at least load your initial conditions to get the plot polulated (no need for a full solve) Oups sorry that applies for V4, in 3.5 its a pain to check ;), I usually defined a force vector along x,y,z in the new coordinate and checked its direction -- Good luck Ivar
Posted: 1 decade ago 15.06.2011, 09:00 MESZ
Hi Ivar,
Hi Ivar, Thanks for your help.
Posted: 1 decade ago 13.12.2012, 10:16 MEZ
Alexandre
Hi, I think the material system should be 34 | 0 | 22. I couldnt figure out why it should be so. But it works.
[QUOTE] Hello, I try to simulate a SC-cut quartz resonator. I use the "Rotation angle method" in the "Coordinate system settings" window to define the orientation but I am a bit confused about the consecutive angles. Should I write 34(x) | 0(y) | 22(z) or -34 | 0 | -22? Thanks for your help. Alexandre [/QUOTE] Hi, I think the material system should be 34 | 0 | 22. I couldnt figure out why it should be so. But it works.
