discontinuity in graph
Posted 29.06.2011, 13:34 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 4.2 3 Replies
I'm trying to simulate a microfluidic channel flow with holes filled with water on the side.
I made two sets of geometries: 1) main water flow channel 2) 20 holes filled with water on the side wall.
They are assembled (not union) and are coupled with a general extrusion.
The results seem to agree wih what I expect it to be, but the problem is when I tried graphing out the velocity profile.. the line cuts off where the two geometries meet.
Would this problem be because of the meshing? Even though if it's a meshing problem, the cut off length is different than the mesh size...
Can anyone help me on how to connect the two velocity profiles smoothly?
Thanks in advance!
Tae Jin Kim
Thanks in advance!
Tae Jin Kim
3 Replies Last Post 04.07.2011, 03:26 GMT-4
