Motion Analysis
Posted 06.07.2011, 02:36 GMT-4 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.1 3 Replies
Hi All,
Im new to using comsol and not sure of its full capabilities....I m working on a project, where I use a resiprocating compressor model (Creo/E). The analysis I want to conduct is to find the pressure and temp difference within the piston cylinder at diferent stages of the piston motion at constant speed. once this is completed I want to change the speed of the piston using diferent mechanism and then find the same and then compare results.
Is this analysis during motion even possible with comsol ?
Thanx in advance
Thanx in advance
3 Replies Last Post 06.07.2011, 03:00 GMT-4
