Mickaël Barsive
COMSOL Employee
7 years ago
10.09.2018, 11:21 MESZ
You can use a rectangle function in "Definitions">"Functions">"Rectangle".
In your case, set "lower limit" at 0.5, "upper limit" at 2.5
then you can plot the graphic to check your function. The next step is to use the function in the physics interface: in your "Inlet" node, you can use the following syntax: rect1(t[1/s])
rect1 is the function name by default and [1/s] is used for homogeneous units.
I hope this helps !
Mickaël
I hope this helps !
Mickaël
7 years ago
10.09.2018, 17:12 MESZ
I hope this helps !
Mickaël
Thank you very much for your help.
>Hello,
>I hope this helps !
>Mickaël
Edgar J. Kaiser
Certified Consultant
7 years ago
10.09.2018, 17:39 MESZ
rectangular velocity steps will probably stop a time dependent solver as a velocity step implies infinite acceleration and thus is unphysical. You may need to smooth the steps. This can be done with e.g. ramp functions. Take care that the time stepping properly resolves the ramp.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
Jeff Hiller
COMSOL Employee
7 years ago
10.09.2018, 19:43 MESZ
Hi Edgar,
The Rectangle function includes (adjustable) smoothing - See GUI.
Jeff Hiller
Hi Edgar,
