Basic question on meshing in 3d and calculations
when you specify the mesh size, does comsol perform a single calculation in the tetrahedron or does it internally breakdown the tetrahedron in several blocks of smaller sizes and then perform the calculations.
thanks
supra
2 Replies Last Post 18.07.2011, 22:37 MESZ
Ruud Borger COMSOL Employee
Posted: 1 decade ago 16.07.2011, 08:54 MESZ
Dear Supradeep,
This depends on the element order - they can be linear, quadratic, tertair, quartic, or higher. Most of the time, quadratic or linear elements are using. In this case, each element has a shape function, where the functions are evaluated on so called Gauss Points. You can view the element order by left-clicking the Physics Interface (for instance "Heat Transfer") and then going to "Discretization". Make sure "Show advanced options" from the Options=>Preferences menu is turned on.
I recommend taking one of our training courses, where this is discussed:
www.comsol.com/events?location=2&type[]=course&sort=start_date
Ruud
Dear Supradeep, This depends on the element order - they can be linear, quadratic, tertair, quartic, or higher. Most of the time, quadratic or linear elements are using. In this case, each element has a shape function, where the functions are evaluated on so called Gauss Points. You can view the element order by left-clicking the Physics Interface (for instance "Heat Transfer") and then going to "Discretization". Make sure "Show advanced options" from the Options=>Preferences menu is turned on. I recommend taking one of our training courses, where this is discussed: http://www.comsol.com/events?location=2&type[]=course&sort=start_date Best regards, Ruud
Posted: 1 decade ago 18.07.2011, 22:37 MESZ
thanks.. got the idea.. on meshing now..
