Simulation with large deformation beam
I am doing a simple simulation of large deformation beam. I made a 2D Al/Ox bimorph and apply thermal expansion with delta T = 300K. I should expect the bimorph would curve into a perfect arc.Just like the first photo. With longer cantilever, it would curve into a circle. But the simlation tell me it will not. It looks like the bimorph will just goes up without curve back. I think the simulation is not correct. I already try to use "Segregated" in the solver but it doesn't work. But how can I change the setting of the solver?
1 Reply Last Post 21.11.2018, 16:08 MEZ
Posted: 7 years ago 21.11.2018, 16:08 MEZ
Updated: 7 years ago 21.11.2018, 16:08 MEZ
For large deformations, you must switch on geometric nonlinearity in the study settings, and ramp up the load using a continuation solver. See for example
https://www.comsol.com/model/large-deformation-analysis-of-a-beam-204
Henrik
Henrik Sönnerlind
COMSOL
Hi, For large deformations, you must switch on geometric nonlinearity in the study settings, and ramp up the load using a continuation solver. See for example Regards, Henrik
