7 years ago
27.11.2018, 06:25 GMT-5
Just an update, I adjusted the meshing which improved the simulation time, ~17 hrs to ~3.5 hrs. The meshing I had not set up to adjust with updates of the models dimensions.
A thought a collegue of mine had was that COMSOL is solving for the more efficient modes of vibration, and with my increase in seperation between the input and output IDTS, the surface wave is now seen as less efficient than the bulk wave as the thickness of the material is considerably less than the distance the surface wave would travel.
So in an attempt to remedy this, I am trying with an increased substrate thickness, comparing with my previous model's IDTs seperation vs substrate thickness ratio.
7 years ago
27.11.2018, 10:46 GMT-5
Update:
Increasing the thickness of the substrate layer appears to improve my results for the suface wave propagation. An FFT of the output signal shows clearer peaks at the frequencies I expect.
My thought is that this thickness increase, minimises the bulk reflected waves produced in the simulation and/or at least increases the propagation distance they need to travel through the bulk of the material and so cause less interference.
I am running models with another increase in thickness, as I think this should produce a clearer output surface wave produced signal.
Another question this has raised for me is that differenct cuts of piezoelectic material have different properties, some more prone to bulk wave propagation while others are less so, does COMSOL take this into account with its predefined material library?
I am only trying 2D models in an effort to save time, and have difficulty understanding how to orientate my material for the correct cut in 2D, I can do it 3D based on the Euler angles, but the 2D rotation set up is different.
Update:
7 years ago
21.04.2019, 22:32 GMT-4
Hi,David Czerski
I'm a student,and studying the" SAW Device Impulse Response In The Time Domain".Can I have a look at this model?
Thank you !
Hi,David Czerski
Thank you !
