Heat source probing of a single domain
Posted 06.12.2018, 04:21 GMT-5 Heat Transfer & Phase Change, Heat Transfer Version 5.1 0 Replies
Hi, I am simulating time dependent heat transfer of an IC. The IC have several heat sources that are temperature dependent and I like to probe those heat sources in order to have the temperature and power for each required domain varies time The temperature probing was easy but when come to the power deification probe I have some difficulties. I specified a domain probe and in the Expression the only options I find are: Ht.Qtot – Total heat source, Ht.Qlnt – Total heat source, Ht.solid1.Qint – total heat source. All give me the total power of all the heat sources together and not the specific domain I specified at the source selection. Is there a way to prove one domain power dissipation (heat source) ? Thank you.
Hello Tamir Zaltsman
