converting from 2D to 3D
I have the following question
In a 2D axisymmetric model I apply a volume force which is dependent on r and z and it works fine
Now I wish to insert my 2D model as a cylindrical domain into a 3D model
It seems there is no way to apply the same volume force as I did in the 2D model because the
only options are Fx Fy and Fz and I can't apply the same axisymmetric force that I had in the 2D model
please advise
David
2 Replies Last Post 22.08.2011, 04:47 GMT-4
Posted: 1 decade ago 22.08.2011, 01:54 GMT-4
what about defining a cylindrical coordinate, or define yourself variables like r = sqrt((x-x0)^2+(y-y0)^2) (if its nicely aligned along x,y,z).
But the COMSOL coordinates system nodes allows you to easily define any orientation
Hi what about defining a cylindrical coordinate, or define yourself variables like r = sqrt((x-x0)^2+(y-y0)^2) (if its nicely aligned along x,y,z). But the COMSOL coordinates system nodes allows you to easily define any orientation -- Good luck Ivar
Posted: 1 decade ago 22.08.2011, 04:47 GMT-4
Hi Ivar
Thanks for your response.
I can define cylindrical coordinates but I cannot work the entire 3D model in cylindrical coordinates
The volume force node is still in cartesian and so it is impossible to define an axisymmetric force.
David
Hi Ivar Thanks for your response. I can define cylindrical coordinates but I cannot work the entire 3D model in cylindrical coordinates The volume force node is still in cartesian and so it is impossible to define an axisymmetric force. David
