How to extract the stiffness Matrix for a certain element?
Posted 30.08.2011, 16:21 GMT-4 Interfacing, Materials, Mesh, Results & Visualization Version 5.2 8 Replies
Hi. I need to extract the stiffness Matrix for a certain element or node before assembling. The "mphmatrix" command gives me the results for whole geometry (After assembly). I wonder if there is any way for getting the matrix for certain elements? For example say that element number 2 or ... .
I appreciate your help,
Masoud
Any command in the API except the "mphmatrix"? Can I use mphmatrix for getting the results for any desired element or node?
Does "NO Reply" mean that COMSOL does not have the ability of doing such a simple stuff?
I do not think so. So please help if you know.
May any of the "Moderator"s help me in this problem?
I have same problem with you. But there is no way to extract the local matrix for element in a manual.
Did you solve this problem?
How about sharing this problem?
in COMSOL you do not access a Mesh element or a node, you access values from a geometric ELEMENT: a point, an edge, a surface, a domain, or a subset of the three last ones
You apply the physics to the geometric elements NOT to the mash, the latter is mapped onto the geometric Elements.
Just as you apply shape functions of higher order and not 2nd 3rd order mesh elements, as in "classical" FEM programmes. You need to get this methodology change into your habits, then COMSOL becomes far more easier to understand, at least that was my experience, coming from many years of "classical" major FEM programmes ;)
I have a question regarding the stiffness Matrix derivation of the model. Suppose that dependent variables of the model are displacements (u v) and scalar potential (V); the command
str = mphmatrix(model,'sol1','Out',{'K','L'})
returns a 4659X4659 matrix for K.
How can I interpret the Global stiffness matrix and Load vector? I need to know which coefficient corresponds to which degree of freedom? In the other words, how is the order of the returned matrix for solution vector, Load vector and Stiffness matrix ? e.g. is the solution vector order like [u1,u2,u3,u4,......v1,v2,v3,v4,.......V1,V2,V3,...] or [u1,v1,V1,u2,v2,V2,.......]
Any and all help is gratefully appreciated!
Alireza~
str = mphmatrix(model,'sol1','out',{'E','D','K','L','Null','Nullf','M','N','uscale'},'initmethod','init');
strc = mphmatrix(model,'sol1','out',{'Ec','Dc','Kc','Lc','Null','Nullf','M','N','uscale'},'initmethod','init');
However, E D K and L are not the desired ones, i want the matrix for the future computation in temporal discretion. And I find Null*E*Null' does not equal to Ec.
Could you express for me in details!
Thanks a lot!
Ivar, suppose I pick the nodes that define one triangle of a triangle mesh. Is there a way to get the shape function matrix (N) and the displacement differentiation matrix (B) for that given set of nodes (that form an element)? Can COMSOL tell me what the element mass, stiffness, damping matrices would be defined on those nodes? We assume that we are using a defined material and same element type used in the global model (i.e. P1, P2, P3, etc.).
