Calculating of inductance of coil in Time dependent
Hello
I have a 2D coil with AC current excitation in Time dependent.But i can't calculate 'mf.Lcoil' in Global Evaluation.
Thank for your reading
3 Replies Last Post 21.12.2018, 19:16 MEZ
Posted: 7 years ago 20.12.2018, 16:49 MEZ
The mf.Lcoil and related values are available in sinusoidal steady state (frequency domain) analysis.
Do you have a reason for NOT using frequency domain analysis??
D.W. Greve DWGreve Consulting
The mf.Lcoil and related values are available in sinusoidal steady state (frequency domain) analysis. Do you have a reason for NOT using frequency domain analysis?? D.W. Greve DWGreve Consulting
Posted: 7 years ago 21.12.2018, 08:17 MEZ
Updated: 7 years ago 21.12.2018, 08:21 MEZ
Thanks for your comment Mr D.W.Greve
I have simulated the coil moving uniformly along a defective magnetic conductor ( by using Moving Mesh (ale) ),try to find the connection between speed and inductance of coil.
I want to know if i can calculate the inductance of coil by 'mf.Vcoil'(Voltage of coil).
Thank you.
>The mf.Lcoil and related values are available in sinusoidal steady state (frequency domain) analysis. > >Do you have a reason for NOT using frequency domain analysis?? > >D.W. Greve >DWGreve Consulting Thanks for your comment Mr D.W.Greve I have simulated the coil moving uniformly along a defective magnetic conductor ( by using Moving Mesh (ale) ),try to find the connection between speed and inductance of coil. I want to know if i can calculate the inductance of coil by 'mf.Vcoil'(Voltage of coil). Thank you.
Posted: 7 years ago 21.12.2018, 19:16 MEZ
No, you can't.
You need to think about how the inductance is calculated in sinusoidal steady state (frequency domain).
A phasor current I is forced and the phasor voltage V is calculated. The impedance is modeled by a resistance in series with an inductance. So Y = I/V = jwL + R. The inductance is calculated from the imaginary part of I/V, resistance from the real part.
NONE of the quantities mf.Vcoil, mf.Lcoil, mf.Rcoil are defined in time dependent analysis. You DO have V(t) and I(t), neither of which is exactly a sinusoid.
> I want to know if i can calculate the inductance of coil by 'mf.Vcoil'(Voltage of coil). No, you can't. You need to think about how the inductance is calculated in sinusoidal steady state (frequency domain). A phasor current I is forced and the phasor voltage V is calculated. The impedance is modeled by a resistance in series with an inductance. So Y = I/V = jwL + R. The inductance is calculated from the imaginary part of I/V, resistance from the real part. NONE of the quantities mf.Vcoil, mf.Lcoil, mf.Rcoil are defined in time dependent analysis. You DO have V(t) and I(t), neither of which is exactly a sinusoid.
