coalescence of 2 particles under surface tension of surrounding medium
Dear all,
i am a phd student and I am stucked in an important model in my phd thesis. I am trying to model the coalesence of 2 visoelastic polymer particles under the surface tension pressure of the surrounding water medium.
please can help me in which modules I have to use to model this coalesence?
Thanks in advance
2 Replies Last Post 07.02.2019, 14:13 MEZ
Posted: 7 years ago 06.02.2019, 14:05 MEZ
Updated: 7 years ago 06.02.2019, 14:06 MEZ
probably you can use FSI (fluid structure interaction) and 2 phase flow
probably the best way to start is to do some tutorials first:
https://www.comsol.com/model/inkjet-nozzle-8212-level-set-method-1445
https://www.comsol.com/model/two-phase-flow-with-fluid-structure-interaction-fsi-in-3d-4515
hope this helps
Hi, probably you can use FSI (fluid structure interaction) and 2 phase flow probably the best way to start is to do some tutorials first: https://www.comsol.com/model/inkjet-nozzle-8212-level-set-method-1445 https://www.comsol.com/model/two-phase-flow-with-fluid-structure-interaction-fsi-in-3d-4515 hope this helps
Posted: 7 years ago 07.02.2019, 14:13 MEZ
Thank you for your answer
the problem that i face that i can't use the surfac etension for the fluid module to intertact with the solid in the structure mechanics module
because the surface tension can be applied only to fluid-fluid interface while i have to add the viscoelastic properties through the solid mechanics module
Thank you for your answer the problem that i face that i can't use the surfac etension for the fluid module to intertact with the solid in the structure mechanics module because the surface tension can be applied only to fluid-fluid interface while i have to add the viscoelastic properties through the solid mechanics module
