energy storage device (non isothermal flow)
Posted 04.10.2011, 21:03 MESZ Heat Transfer & Phase Change Version 4.2 3 Replies
hello sir,
I have a simple setup in which hot water is flowing inside the solid steel cylinder, I want to see how temperature profile changes with time. during flow water will give its energy to cylinder, hence water temp at outlet should be lower than inlet.
when I run it using time dependent solver it gives the error as "failed to find consistent initial values"
i m attaching the file
please help.
please help.
3 Replies Last Post 06.10.2011, 16:25 MESZ
