Henrik Sönnerlind
COMSOL Employee
7 years ago
22.03.2019, 09:48 GMT-4
Updated:
7 years ago
The first question here is whether you are using an ordinary Frequency Domain study, or one that is of 'perturbation type'. The linper() operator only contributes to a perturbation type of study.
To me it seems that you should use the expression “-lms.E136_f2 + 1” and use ordinary Frequency Domain. All loads are then implicitly assumed to be periodic.
Henrik
Henrik Sönnerlind
COMSOL
Henrik
7 years ago
22.03.2019, 11:28 GMT-4
Henrik
Thenk you Henrik for your reply.
Yes I want to do an ordinary Frequency response where I want only one force which has a magnitude of 1 N to be periodic where the other reactions forces are staionary.
Abdullah
>Hi,
>Regards,
>Henrik
Abdullah
Henrik Sönnerlind
COMSOL Employee
7 years ago
25.03.2019, 03:41 GMT-4
Hi Abdullah,
If you want part of the forces to be stationary, and part to be harmonic, then you need to use an analysis setup which is similar to 'Frequency Domain, Prestressed'. That is: one Stationary step for the static preload and one Frequency Domain step of perturbation type with the stationary solution as linearization point.
In such a setting, your original expression contating linper(1) for the harmonic part is the correct one.
Henrik
Henrik Sönnerlind
COMSOL
Hi Abdullah,
Henrik
7 years ago
26.03.2019, 14:00 GMT-4
Hi Abdullah,
Henrik
Hello Henrk,
Yes it does work. Thank you very much. I will really appreciate your help and I am sorry if I cause any trouble.
Abdullah
>Hi Abdullah,
>Regards,
>Henrik
Hello Henrk,
Abdullah
